June 2012 Muffler Change
14 Guests, 2 Users
kodai, DanB
February 13, 2016, 01:15:07 am
Author Topic: Horn hanging by thread  (Read 552 times)
Chasfield
« on: June 15, 2013, 07:27:46 am »
I noticed that my horn was hanging by its wires (which is better than just finding the wires!). I had read that the horn bracket was prone to fracture and sure enough mine had split across the mounting hole. This is very easy to fix. All I did was cut away more of the bracket before its final bend to leave a flat plate instead of the stock ninety degree arrangement that it started out with. I then drilled the shortened bracket to fit the engine plate stud that originally located the horn.
Of course the horn now rides side saddle instead of facing front but I reckon this is better for aerodynamics.
2001 500 Bullet Deluxe
Re: Horn hanging by thread
« Reply #1 on: June 15, 2013, 08:18:21 am »
Definitely better for everything.
Reliability of mounting and function,  and probably better aerodynamics and better cooling to the engine too.
ROVERMAN
« Reply #2 on: June 15, 2013, 03:38:18 pm »
I too suffered the dreaded horn dangling disease. I had a Range Rover horn and bracket laying around, chop,chop on the bracket and it looks like it was made to fit there!
curtisbelford
« Reply #3 on: June 17, 2013, 12:22:42 am »
The way I figure it, With my exhaust pipe. They would hear that befour they hear the horn. LOL  ;D
AgentX
« Reply #4 on: June 18, 2013, 01:58:31 am »
They'll only hear your exhaust note when they're in a position to be of little threat to you.
