Trizuki
February 06, 2016, 05:36:12 pm
Author Topic: Ditch your stock chain!  (Read 6504 times)
swingarm
Re: Ditch your stock chain!
« Reply #45 on: June 18, 2013, 05:54:26 am »
Thanks bill.
heloego
« Reply #46 on: June 18, 2013, 10:04:43 am »
Sectorsteve,
It might not be convenient for you but for your sake and the sake of others, both current and future owners, it might pay to bump things up a notch and file a complaint or more with RE Corporate since the bottom two links on the chain (pun intended) are giving the company a bad name.
Often a word or two from the right people will work wonders changing a sh*thead's attitude about his customers.
wildbill
« Reply #47 on: June 18, 2013, 07:46:40 pm »
sectorsteve
will get a photo off to you today. once i get notice from the dealer for the arrival date of the cafe racer -my c5 goes anyway.
thought about keeping both but if you look at the bird in my profile chewing up my cash fund.......looks like i only keep one!
2011 C5 black/chrome
2012 C5 maroon/chrome
2013 B5 black
2014 Continental gt
2014 C5 tan
2015 black/chrome
2015 limited edition dispatch
2016 lagoon blue
2004 mazda-speed miata
2001 bmw z3
« Reply #48 on: June 18, 2013, 08:01:29 pm »
i replaced my oem "Indian Diamond " chain with just over 10k...It had stretched a bit  and I did adjust twice over the mileage stated...It's hanging  on a nail in the garage  straight with no kinks and further inspection didn't show any serious wear between the links..Maybe its the lube i'm using ...My teeth look okay too..
« Reply #49 on: June 18, 2013, 09:13:32 pm »
That's good.  Oral hygiene is important.
Scotg
Sectorsteve
« Reply #50 on: June 18, 2013, 11:11:04 pm »
Holego I'm all for this. Wild bill should also lodge a complaint as he had a dodgy C5 that he sold because he said it was rubbish.
« Reply #51 on: June 18, 2013, 11:33:48 pm »
I lube twice per tank of gas or more. I ride on dusty and some dirt roads.
What kind of lube are you using? Im thinking of switching to ATF on the chain.
Sectorsteve
« Reply #52 on: June 18, 2013, 11:48:58 pm »
Letter sent to RE corporate.
dougodewitt
  • 2010 Bullet C5; Teal
« Reply #53 on: June 19, 2013, 10:39:21 am »
I lube my chain before every ride; I bought my C5 from the second owner, at about 1100 mi on the clock. How do you tell if you have the stock chain or if it is an aftermarket chain? And how do you tell if your sprockets are being damaged? Mine seem to look fine, but without experienced eyes who knows?
RIDE, ride, NOW! Ride!
Gypsyjon
« Reply #54 on: June 19, 2013, 10:44:37 am »
Okay, you guys scared me enough...ordered my O-ring chain today...
THX!! ::)
heloego
« Reply #55 on: June 19, 2013, 10:45:13 am »
Good on ya!  :)
Royalista
  • phaneropter
« Reply #56 on: June 19, 2013, 03:10:27 pm »
Conventional way is to lube after the ride when the chain is still warm.
Lube will easily go where it has to go and will be dry before the next ride so it will not splatter off.
Overlubing does not yield a benefit, is just a waste of money.
But lubing after a ride in the rain is good practice.
The manual has a nice picture of healthy and bad teeth.
Bad teeth look spiky and will eventually break off with a nice twang. That's a good give away.   :'(
moriunt omnes pauci vivunt
« Reply #57 on: June 19, 2013, 05:50:28 pm »
dougo
Here is a link that gives a lot of information about chains including a drawing showing how a totally worn out chain can be pulled up off of the rear sprocket.
I've never seen one that could have its link become as disengaged as the drawing shows but it shows the general idea.  IMO, of the link can be pulled up off of the sprocket  teeth over 1/8 inch, it is time to get rid of it.
http://www.bikerenews.com/Stories_Archives/Chains.html
Actually, I don't think my chain was even that bad but when I had to adjust it 3 times in just 3000 miles to get the right amount of looseness I said to myself, "Enough!  Be gone with you!"
A good chain can go much further without needing adjustment to keep the right amount of chain slack.
« Reply #58 on: June 19, 2013, 07:00:36 pm »
repozer:   type f and wee bit of left over oil..i brought one of those old fashion oil can with a adjustable skinny spout.. like in the wizard of ozz to oil the tin man..  ;D
dougodewitt
« Reply #59 on: June 20, 2013, 05:19:17 pm »
dougo
Thanks man! I really needed that!
