Just finished a 250-mile drive from NYC to DC and I ran into a bunch of small (?) mechanical problems on the way. Nothing that prevented me from finishing the trip, but...
First of all, at mile 100 at a rest stop I realized that the front bolt that secures the neck of the gas tank had lost its nut and was itself about to fall out! A competent mechanic on the scene tried to find a matching nut, failed, and then improvised a solution. He took an old bolt he had on hand, cut it down, put a sheath (an old socket) on the head end to position the threads in the right place, and put a nut on it. It pokes out 2 inches on the left and limits the leftward turn of the handlebars (so for instance I can't engage the fork lock), but the bars never turn that far when the bike is actually in motion. I'll order the factory parts when I get home and fix it right.
Second, the airbox (on the right, below the seat) kept popping open in the rain! The sound of the engine changes so I notice that immediately and pop it closed again. If a little rain gets in there, will it create a problem?
Third and most importantly: I can't reach first gear anymore, and can only intermittently reach neutral. If I kick it down as far as it can go, I mostly end up in a false neutral that's in between second gear and actual neutral. The lower gears have always been balky but until now I could always get into neutral or first (when it stuck) by letting out the clutch or rolling onto the throttle a bit. Not anymore.
The bike is perfectly drivable without a first gear, you just need a bit more clutch finesse from a dead stop (and I've been driving stick for 30 years, so I can handle that ), but it feels ridiculous.
I don't have a good mental picture of the innards of my transmission (and even if you showed me one I'd struggle - I'm not visual in that way). What do you think is happening? Bike is under warranty but to be honest I don't know if I trust my dealer to take the transmission apart.
