morning! I have a 2009 C5 500. Put it away with fuel stabilizer, battery tender etc. Tried getting it out this spring and has a problem it didnt have when put away. Really wants to run rough. Hard to start, even with fresh gas, Once started wants to stall. If I keep working the throttle I can prevent that and get it on the road, but it isnt destined to take me anywhere. It again seems to want to stall. Throttle response becomes "herky-jerky" even when turned gently. At times, it sounds like the ignition shuts down, then lights up again (LOADS of fun on a 2 wheeler....) Other times it acts like a carburated bike with a clogged main (ie: runs at idle, but bogs as soon as you give it some throttle) ALL this joy on one ride out a mile (and barely back to the garage...) It's kind of hard to describe all the farting, backfiring and general garbage it's doing. Please ask me any specific questions which might help! Sadly it was running GREAT when I put it away...
No ECU codes are showing.
I have been thinking loose connection somewhere? But I dont know where to check for connections in the ignition system. Any helpfor where to start looking?
I was also thinking clogged injectors? I havent been able to keep it running long enough to run anything through in the gas, like cleaner or Seafoam.
