while i appreciate the technical stance provided, i must reiterate my fix of wave washers(4, 2 for each peg). my pegs were hard to flip into position using my feet while underway, so i had to do something immediately(i choose to cruise with my feet on the rear pegs).then when i tried to put them up, they kinda flopped. hence the wave washers. still have all oem parts i've chosen to remove, but if you want it to work, this is an alternative. good luck!
