So what did the problem turn out to be?
The fender under the seat area is supposed to seat into a bushing under the plastic fender which is attached to the bike.....I really don't see how this is possible...because the small 10mm nut is NOT going to hold the metal fender in place.....
If its supposed to go above the plastic fender that's not possible either because the plastic fender is wider than the metal fender..so it's not going to fit...
Scottie could you please see how your fender is sitting inside under the seat in the plastic fender area , is it just free hanging in there or is it attached to the plastic fender somehow...
Since I could do 82 mph without the fender on, it seems like it is a fender issue somehow.
