Modified 350
May 30, 2016, 09:09:16 pm
Author Topic: 2007 Electra  (Read 2535 times)
DanB
Re: 2007 Electra
« Reply #15 on: May 22, 2013, 05:54:55 pm »
I can get u one later when I get home. Snidals manual has all this.
What happened with the smoking issue?
2006 AVL Electra
DanB
Re: 2007 Electra
« Reply #16 on: May 22, 2013, 10:43:24 pm »
Here you go.  From the owners manual.
« Last Edit: May 22, 2013, 11:02:50 pm by DanB »
2006 AVL Electra
Techmaven
Re: 2007 Electra
« Reply #17 on: May 23, 2013, 03:55:49 am »
I haven't run it since then..gonna re-install all the stock lights, new exhaust gasket and mirrors. After that I'll see what-up with the smoking. I'm sure it's the breather setup somehow.
Techmaven
Re: 2007 Electra
« Reply #18 on: May 23, 2013, 05:38:50 pm »
Appreciated but it's just a bit blurry when enlarged enough for my failing eye sight. Question for anyone..Exhaust flange at head has 2 washers under each nut and when tightened fully, the pipe still moves/leaks.
 I have a new gasket and am wondering if a pair of 1/4" long brass bushings to replace the washers be advisable to take up the needed slack?
Techmaven
Re: 2007 Electra
« Reply #19 on: May 26, 2013, 02:50:41 pm »
Saw a vid on youtube  http://www.youtube.com/watch?v=qWczauM-nFs..I did what he did here and keeping fingers crossed that the smoke stops..Stock signals are back on too.
Techmaven
Re: 2007 Electra
« Reply #20 on: May 26, 2013, 04:08:36 pm »
and airbox was filled with a good amount of moisture laden oil..checking oil warm shows it at the top of the hash mak without screwing in the stick/cap. Too much?
Re: 2007 Electra
« Reply #21 on: May 26, 2013, 05:56:04 pm »
I'd say yes. You want it about half way up.   ERC
DanB
Re: 2007 Electra
« Reply #22 on: May 26, 2013, 10:34:41 pm »
You need to make a simple modification to the breather system. Simply reverse the hose that goes from the crank case to the can.  Let it run straight up over the frame and then over to the can. First though, you'll need to pull the battery out and get into that oil catch can to empty it.  Its over flowing and is blowing oil into your air filter.
Before doing anything, I strongly recommend some research.  Read this whole thread: http://www.enfieldmotorcycles.com/forum/index.php/topic,12620.0.html
I ended up keeping the can, but I:
1) Capped off the timing return line at the timing cover.
2)  Ran a clear hose from the crank breather, up and over the frame then to the can using the original duckbill
3)  Kept the primary case oil breather, as I keep 1 liter in there to preserve the sprag gear (No problems yet, but i dont use the ES often).
4) Created a drain hose using the timing return hose with a plumbers valve on it.  I can now drain the can without pulling everything apart.
Once done, I'd recommend changing the oil (if not done already as its a 'new to you' bike) and never add more that 1.75 l.  Check oil after running the engine for a few minutes and shot for a the 1/2 way mark that ERC pointed out.  make sure the oil fill cap is screwed in all the way.  You'll get a feel for it.
2006 AVL Electra
Techmaven
Re: 2007 Electra
« Reply #23 on: May 27, 2013, 05:40:05 am »
I cleaned out the airbox and blew out the hoses..smoke looks to be ceasing now. I pulled all three hoses off the can and nothing came out. does it have to be removed to be drained? I'm going to post pics of my setup later since it's different than yours.
Techmaven
Re: 2007 Electra
« Reply #24 on: May 28, 2013, 09:23:27 am »
Dan, thanks for the breather info. I'm in the process of doing what you said. I think my camera is in the wife's car at work and I wanted to take a pic of another hose I have on the bike. It runs from the air box to a valve assembly bolted to the head on the left side. The AVL in the thread you link does not have this, that bike shows just a bolt in the head in that location.
DanB
Re: 2007 Electra
« Reply #25 on: May 28, 2013, 12:39:36 pm »
That's the PAV. Pulse air valve. It's used to injected a pulse of fresh air for emissions and to cool the exhaust valve. It's been removed by many owners, but really has nothing to do with the issue at hand for you. You can pull it and then block off the exhaust opening with a domed cover bolt sold by our hosts. You'd also need to cap off the air line that goes to the inlet manifold.
With that said, i suggest one thing at a time. Save the PAV mod for a later day and focus on the breather. The PAV doesn't hurt anything and is a good mod when you change the carb.
2006 AVL Electra
Techmaven
Re: 2007 Electra
« Reply #26 on: May 28, 2013, 06:46:50 pm »
I pulled the hose off the PAV valve and blew a shot of compressed air through it..it was a bit clogged at the airbox end.
« Last Edit: May 30, 2013, 08:12:49 pm by Techmaven »
Techmaven
Re: 2007 Electra
« Reply #27 on: May 30, 2013, 08:16:09 pm »
Got the bike all legal today...Smoke stopped, Signals back on and she's puttin' along like a champ. The tail light previous owner installed required him to drill some holes..one of which ISN'T covered by the huge stock light  assembly..Looks like I have some body/paint work in my future.
DanB
Re: 2007 Electra
« Reply #28 on: May 30, 2013, 09:32:42 pm »
Good to hear and nice job. Keep an eye on that catch can. Left stock, it's only a matter of time before it spews oil into the air box again.
2006 AVL Electra
