PCPaul's 2012 B5
February 10, 2016, 10:35:03 pm
Author Topic: A little ID help please  (Read 1903 times)
jperryj
« on: June 09, 2008, 08:03:54 pm »
I'm trying to ID a RE motorcycle for my buddy. The numbers I found on the bike are;
1A 578 on the engine
AGZ 2750 on the gear box
4759 on the frame
Can anyone help ID this bike? It's been sitting in a garage for a few years and now he wants to get it up and running, but we need to know what it is first, right?
Thanks for your help,
JP
Brother Rhett
  • I chase shiny objects across the internet.
Re: A little ID help please
« Reply #1 on: June 10, 2008, 03:42:48 pm »
Hi JP,
Welcome to the forum! Can you post a picture or describe the bike?
-RW
What wouldn't you not do if you didn't know you wouldn't fail?
rotorwrench
« Reply #2 on: June 10, 2008, 05:39:29 pm »
The frame number is a bit odd for the bike. You have a series 1A Interceptor from 1968. The transmission number looks a bit older maybe series 1. The frame may be correct but usually matches the 3 digit engine number. I have some older frames from late 50s Indians that have similar frame numbers but even the old frames will work with a little modification for the top engine steady plates.
Check on Burton's Bike Bits web-site for an Interceptor register that gives a lot of identification information.
