Latest add-ons
31 Guests, 2 Users
iRideRoyalnVA, Arizoni
May 27, 2016, 11:12:15 pm
Author Topic: Mystery wire identification  (Read 2516 times)
Re: Mystery wire identification
« Reply #15 on: May 27, 2013, 01:58:40 pm »
Well, if it works it works!  I'd have spent a bunch of my time putting the headlamp back on the AC circuit.  But, I'm not known for always doing the simplest, most elegant thing.  Your way your headlamp doesn't dim at stoplights.
herrbongo
« Reply #16 on: May 28, 2013, 03:22:22 pm »
That is what I wanted too, but try as I might I could not see where the AC circuit came out of the harness at the front.  I didn't want to slice into the harness to figure it out either.  It's still charging, and I'm going to start racking up miles to see what other problems are lurking before a big ride to Canada later this month.  We'll know soon if it's going to fry the rectifier.
1962-2000 G2 Mystery-year Bullet 500cc
Yamaha RD350 & CS3E
Air-cooled VWs
AgentX
« Reply #17 on: May 29, 2013, 09:26:12 am »
I ran a 4-wire to a DC-only setup.  Two leads each went to one of the two input wires to the DC R/R.  But there was one way that they worked, and another which put out next to nothing.  Assume that was a phasing thing.  When hooked up together in the right order, it gave plenty of power.  Unfortunately the right order was only discernable (for me) by trial and error.
herrbongo
« Reply #18 on: May 29, 2013, 11:49:23 am »
AgentX, I'm glad you validated that setup.  I think I will go the next step and connect as you descrbe for max output.  Have you ever had problems with the Reg/Rec after hooking up?  That is my only worry.
Yamaha RD350 & CS3E
Air-cooled VWs
« Reply #19 on: June 01, 2013, 12:05:34 am »
What your looking for on the wires is color coding.  Of the 4 wires, 2 wire insulations should be of the same color but different color stripes.  The other 2 should have a different color but match with different color stripes.  Example: blue/black stripe & blue/white stripe and green/black stripe & green white stripe.  Match the same color insulations together to 1 wire on the R/R and same with the other 2 wires.
AgentX
« Reply #20 on: June 01, 2013, 07:01:01 am »
Hm, mine had 3 amber and one purple as I recall.  Could only do it by taking an initial guess and seeing how it worked.
herrbongo
« Reply #21 on: June 14, 2013, 03:48:38 pm »
Following up; I wired the 4 alternator output wires parallel into the two leading to the battery, and all is well.  The indicated charge on the ammeter goes nicely positive as it restores the battery after idling with headlight on, then levels out to just a hair positive after a block or two.  Before I would never see the needle much over a hair positive.  Been riding it to work all week and holds the same charge day after day.
Yamaha RD350 & CS3E
Air-cooled VWs
« Reply #22 on: June 14, 2013, 03:55:22 pm »
That's great news!  Glad you got it straightened out.  Do you by chance remember what the color coding was?
