'01 Military
19 Guests, 2 Users
chuychacon, kodai
May 24, 2016, 08:53:56 am
Author Topic: "Popping" off throttle, deceleration  (Read 2684 times)
boggy
  • Karma Ultra: 7
Re: "Popping" off throttle, deceleration
« Reply #15 on: May 15, 2013, 10:25:18 am »
Resourceful, and maybe my only option.  None of the bike shops around here, or any of the Auto-zone/Advanced-autos have it.  Not the sort of grey, metal looking tape I was looking for anyways.
Ace, so just cut a strip off of the beer can and use it like a collar around the header-pipe's end?  I'd imagine a little air would still sneak out, but maybe that's no big deal.
2007 AVL
2006 DRZ400SM
« Reply #16 on: May 15, 2013, 11:27:26 am »
Auto-Zone has an aluminum tape that will do the job. I used it on my pipe/muffler joint. It worked quite well. I think it's called muffler tape.
For a better gasket, go here
http://www.aircraftspruce.com/search/search.php?s=crush+gaskets&x=0&y=0
« Last Edit: May 15, 2013, 11:33:16 am by barenekd »
boggy
  • Karma Ultra: 7
« Reply #17 on: May 15, 2013, 12:05:48 pm »
I think I'll try those gaskets.  Can I use 3m Alluminum tape?
http://www.shop3m.com/70006006525.html?WT.mc_id=GoogleProdSearch&gclid=CNbYkcTKmLcCFUHe4AodMTcAIQ
Says up to 600 degrees.
2007 AVL
2006 DRZ400SM
« Reply #18 on: May 15, 2013, 12:21:42 pm »
I always used the hi-temp rtv sealant...
     just gotta let it cure fer 24 hours.
               - Mike
boggy
  • Karma Ultra: 7
« Reply #19 on: May 15, 2013, 12:26:38 pm »
Baird, what was your method of application?  My header diameter is quite a bit smaller than the port opening.  You just lather it up around the header pipe?  Easy to clean out if you need to remove the pipe again?
Thanks.
2007 AVL
2006 DRZ400SM
« Reply #20 on: May 15, 2013, 12:41:42 pm »
thoroughly clean port and pipe with small brass brush and then wipe down with rubbing alcohol.
run about a 3/16" bead  around outside diameter of pipe at end, then insert and tap in with rubber mallet....
I guess I should say that the rest of the exhaust should be attached but loose....
then start aligning and tightening everything werking your way back. Should only take a few minutes...
then if there is too much excess sealant or it is uneven, it can be smoothed.
now fer the hard part; use some self control and let it dry and cure for 24 hours.
           - Mike
« Reply #21 on: May 15, 2013, 03:41:37 pm »
You can take the header pipe to a local muffler shop and have them expand it a bit or use a strip of pop can along with some silicone.
2009 HD FLHT Police 103 6 spd
