Author Topic: small grease nipples  (Read 1067 times)
MissSpentYouth
on: May 08, 2013, 05:33:27 pm
Hi All, I have recently purchased a 1990 350 Bullet and it has a number of small grease nipples on it. To small to take my grease gun which has a flexible rubber end on it terminated in a standard grease nipple socket. By standard I mean the ones you get on old MG and triumph cars. Do I need to go and buy a new grease gun with a ridgid end the pump action type that doesn't grip onto the grease nipple with fingers but just sits on it. Or can you swap them out for larger ones or buy some kind of adaptor ? cheers Ben
AgentX
Reply #1 on: May 08, 2013, 05:52:11 pm
I don't know what you have on your bike, but a bicycle shop can sell you a mini-grease-gun that threads onto tubes of lithium grease, etc, also sold at a bicycle shop.  The gun fits the small grease zerks used on some full-suspension bikes.
If that helps...
Reply #2 on: May 09, 2013, 02:21:58 am
 Both grease couplers and grease zirks are wear items and cheap as chips to change when either leaks.
