Yellow CGT
18 Guests, 2 Users
Mandar_C500, finbullet
June 01, 2016, 02:32:42 am
Author Topic: Replacing Crank Seal On 700 Twin  (Read 722 times)
« on: May 08, 2013, 01:10:26 am »
I have a bad oil leak between the primary case and the engine block where the crank is.  Is it the chain case oil seals that I need to replace?  Also, can I install them with out disassembling the motor?  I need to replace the alternator and was thinking of just replacing those seals while I was in there and had it tore apart.
Re: Replacing Crank Seal On 700 Twin
« Reply #1 on: May 08, 2013, 08:15:51 am »
Yes you can replace the seal on the inner primary. Depending which primary is on the motor the later ones are a rubber seal the early ones are felt. there is also a seal for the gearbox shaft, can be eithe rubber or felt. If it's felt you can put a bullet 4 speed rubber one on that shaft. You don't need to disassemble the motor.   ERC
« Reply #2 on: May 08, 2013, 08:22:56 am »
Thanks ERC.  From looking at Hitchcocks, it seems like I have the multi-piece felt seal set.  I believe the transmission shaft seal is rubber though.  Either way, they're cheap and easy to replace.
« Reply #3 on: May 08, 2013, 09:40:37 am »
Don't order anything till you pull it apart, you never know what inner primary you may have on there. the bikes old and may have been changed to a later or earlier one. They all bolt on the same basically.  ERC
« Reply #4 on: May 08, 2013, 10:26:15 am »
Eff that crap.  I'll order both and send back what I don't need.  That's too much down time.  I want to ride now damn it!  LOL  Actually it's going to rain all today.  Bummer, I wanted to try out the new GPS speedometer app I downloaded for my phone.
« Reply #5 on: May 08, 2013, 10:54:01 am »
I may have both types at home I'll check, the shipping would be cheaper.  ERC
« Reply #6 on: May 08, 2013, 11:55:09 am »
I've got the big and small felt ones, no rubber ones.  ERC
