Bullet Delhi
February 11, 2016, 03:21:16 pm
Author Topic: Primers and Paint  (Read 567 times)
Primers and Paint
« on: May 07, 2013, 06:23:55 am »
I've got bare metal on my swing arm where I had a broken stud replaced.
I've also got surface rust inside my wheel rim where the tire seats against it.
It's been suggested that I use self-etching primer on bare metal - I got some in a rattle-can for the swing arm.  Some will end up on the old paint - will this cause adhesion problems, either on top of the original paint or under the new?
I was thinking of wire-brushing the wheel rust and treating it with a rust-inhibitor, followed by a primer coat of something before replacing the tire - can I safely use the same self-etching primer here?
Or should I just get a "regular" primer for both applications?
I know about prepping glossy paint surfaces before recoating, just wondering if anybody knows enough about these primers to steer me in the right direction without me having to stock a paint-shop's worth of products for these minimally-visible to non-visible treatments.  I'm not going for a show bike here; I want to protect the metal, and have it look good enough not to stand out - and I want to ride the darn thing!
Re: Primers and Paint
« Reply #1 on: May 07, 2013, 05:24:26 pm »
Thought I'd try to get the discussion from two different threads to end up here:
Broken swing arm repair: http://www.enfieldmotorcycles.com/forum/index.php/topic,16366.0.html
Rusty wheel rim interior: http://www.enfieldmotorcycles.com/forum/index.php/topic,16385.0.html
I didn't get any bites - the discussion is wandering back and forth between those two other threads, and I've sorted my paint questions, so this one can RIP...
