Author Topic: Howq long did your clutch cable last? (how many miles?)  (Read 7339 times)
meilaushi
  • If it ain't broke, don't fix it! Ride!
I've got about 6000 miles on my iron barrel classic 5 speed (2008).  I was wondering how long the clutch cables on these bikes last, and when, to avoid being stuck out on the road with a broken cable, one ought to change the old cable and put a new one on.  Any experiences, suggestions?
Ralph Meyer
2008 RE Classic Bullet ES :) "Ennypenny" (It's an Enfield and costs pennies to run!)
2010 RE Deluxe G-5 :)) "Eagle"
2010 BMW F800ST
Ridin' 58 years & counting!  Back roads are fun! Member IBA.
Damon
Reply #1 on: May 04, 2013, 03:23:05 pm
Mine broke at the hand lever at about 7000 miles. Not sure if that will be the case for anyone else.
Damon
2005 Royal Enfield Bullet 612 Continental
1965 Royal Enfield Interceptor Mk1
1956 BSA GoldStar DBD34GS Flat track racer
1971 Datsun 510 2-door sedan
ERC
Reply #2 on: May 04, 2013, 03:47:20 pm
They changed the way they hook up in the gearbox on your model so you should be ok for a while longer. You can look at it on the bars to see if it's ok.  ERC
mrunderhill1975a
Reply #3 on: May 05, 2013, 04:03:40 am
I carry a spare cable in the toolbox for just such an occasion.  I have almost 23,000 miles on my 1999 and If I remember correctly, I have changed the cable three times so, approximately every 8000 miles.  If the cable ends are well lubricated, the cable seems to last longer.  The cables also last longer when the clutch springs are OEM rather than HD.
c1skout
Reply #4 on: May 05, 2013, 06:25:35 am
I've got over 14,000 on my original cable so far (2000 4-spd). I lube the cable with atf twice a year and grease the lever end and pivot at the same time. I'm still running all my factory cables.
Guaire
Reply #5 on: May 05, 2013, 02:52:25 pm
Hi Ralph - I'm new to Enfields, but old to BSA. For longevity, lube the cable and pivot lead and the lever. I use one of those rubber cable lube attachments that accepts the tube from a can of 'Cable Lube'. Thoroughly lube the pivot with grease. Without the lubed pivot, the lever can turn the cable end against the cable. That really shortens cable life. Later setups added a plastic sleeve in the pivot to prevent the cable end bending.
  If you doubt your cable's condition -- you can keep your spare pre-installed and tied to the working cable. When your cable breaks, just connect the ends of your replacement, adjust and you're rolling.
Cheers,
Bill
meilaushi
Reply #6 on: May 05, 2013, 09:48:38 pm
Thanks, guys!  Your information is a real help.  I'll check the cable ends--they don't look bad--just adjusted the clutch as it was getting a bit grabby.  I think the info is right that you don't want to keep the bike in gear when stopped at a light as I suspect the clutch throw-out wears.  But I was thinking as I had to also adjust the cable that maybe it was getting a bit longer, and when the bike's hot it doesn't seem to throw the clutch out all the way, so maybe I should adjust the clutch when it's hot.  But the info on cable life is a real help.  Think I'll throw the new one in the saddlebags just in case.
Ralph Meyer
2010 BMW F800ST
Reply #7 on: May 06, 2013, 12:20:11 am
It's not that your cable is getting longer but that as the clutch plates wear it slowly creates "play" in the cable.  Basically as your clutch plates get thinner, the cable needs to be adjusted out to compensate for the missing material on the clutch plates.  And it is best to make the adjustments with the engineer at operating temperature.
I should add that cables can stretch, but this is the result of the cable breaking and fraying away from the ball ends.
« Last Edit: May 06, 2013, 12:32:25 am by Scottie J »
meilaushi
Reply #8 on: May 06, 2013, 01:59:34 pm
Very helpful information, Scottie!  Many thanks!
Ralph Meyer
2010 BMW F800ST
clay
Reply #9 on: May 06, 2013, 02:35:24 pm
I only had 3000 miles before mine went. On a 2005
2005 military RE
57 Sears Allstate 250
61 Sears Allstate 250
69 Sears Allstate 250
66 Sears Allstate 175
74 honda z50
Chasfield
Reply #10 on: May 07, 2013, 07:37:46 am
 Does it not work the other way ? - as your clutch plates thin you end up with progressively more pushrod than you need, which uses up free play, leading to clutch slip.
Chas
2001 500 Bullet Deluxe
Reply #11 on: May 07, 2013, 02:25:23 pm
Chas
[/quote
I have been wrong in the past.  But of the last 8 bikes I've owned since I was 13, I have never adjusted a clutch cable IN.  If a clutch is slipping you either have the cable adjusted too far out or your clutch plates are worn out.  Just my experience.
The Garbone
  • Shade Tree
  • User Complaints: 22
Reply #12 on: May 07, 2013, 03:50:35 pm
10000+ miles on my 07 clutch cable.
Ehh,  on my 95 the clutch is so sensitive I have to adjust it out then in if I let it sit for over a month,  after about 20 miles of use it stretches back out and is good after that.  Of course we are only talking about .5 to 1 turn at the lever.
« Last Edit: May 07, 2013, 03:56:46 pm by The Garbone »
Gary
57' RE Crusader 250
67' Ford Mustang
74' Catalina 27 "Knot a Clew"
95 RE Ace Clubman 535
01 HD 1200 Custom
07 RE 5spd HaCK
Reply #13 on: May 07, 2013, 04:06:18 pm
Personally, I think all RE clutches are fair at best.  I've been on motorcycles for over 20 years and I've never had a clutch act so retarded.  If I move mine any further in it won't disengage.  If I move it any further out, it won't engage.  Who the hell ever came up with the scissor clutch anyways?  They should be slapped.  I'll tell you this much.  When I rebuild this motor in  a couple years, 1 thing I will be looking at is having someone build me a custom clutch.
Reply #14 on: May 07, 2013, 06:11:37 pm
 The clutches by Bob Newby are pricey but favored by those who want or need them.
 A lower cost alternative would be to have you clutches hub and basket faced and trued like our sister Jeri Danger had done to hers.
http://www.enfieldmotorcycles.com/forum/index.php/topic,5101.msg58191.html#msg58191
