Nah,,,no pot stirring mate,,,we are talking technical not political.
Interesting page from the owners club. The single most notable technical point there is the importance of grounds.
The same car with the same bad grounds as alluded to in the club quote is going to suffer corrosion at the same places regardless of the polarity of the electrical system.
From the same article
“All Rolls-Royce cars built prior to the 1940 war, had the negative pole of the battery connected to the frame with black wire connections (plural)throughout to the frame. It is also called negative earth. For some reason, of which I am not aware, the company reversed this procedure when they resumed production after the war”
So in other words pre war Rolls had the negative wire go from the appliance and to the frame instead of through the body to the frame like modern cars.
