First Changes
February 11, 2016, 05:52:45 pm
Author Topic: Finicky starting  (Read 1467 times)
Supesguy
Re: Finicky starting
« Reply #15 on: May 06, 2013, 10:11:26 am »
There could be a defect in the relays. I was able to get a zip tie around the one that kept wiggling loose.  I've done a few moderate to longer rides to see if it holds.  So far so good.  Fingers crossed.  Once I get more time, I'll go through and work on inspecting and protecting wires around the fuse compartment, headlight housing, and other areas.
