I find it fascinating that the manual leaves out the Kickstart instructions, but the kickstart is indicated on the key parts location diagram. I have been using the electric start every time. Am I correct in saying it the same procedure, except you kickstart with the started instead of hitting the start button?
It seems much less complicated in the EFI than in previous incarnations.
