Winter Testing!
37 Guests, 2 Users
The Old Coot, gizzo
May 25, 2016, 06:15:39 am
Author Topic: Mikuni carb kits from Nfield Gear  (Read 583 times)
Dhastings1954
  • 98 bullet Machismo
« on: April 27, 2013, 06:38:33 am »
Anybody know if the Mikuni replacement carbs being sold by NField Gear already have the correct jetting? The sales blurb does not say. Looks like you get everything else you need to convert.
Duncan
Duncan
Vt Bullet
Re: Mikuni carb kits from Nfield Gear
« Reply #1 on: April 27, 2013, 07:25:34 am »
If you are talking about the complete kit with the 34mm round slide Mikuni, I think that does come with the jetting that is recommended.
It also comes with the rubber manifold which is large enough for it, and a nice Motion Pro throttle cable.
Depending on what you plan to do with this engine, you might find that a 30mm or 32mm could do just as well.
ieatalot
« Reply #2 on: April 27, 2013, 09:01:07 am »
Be careful at first mine flooded and spilled gas when I first installed it. I believe it does come properly jetted. Don't forget to set the air mixture though.
curtisbelford
« Reply #3 on: April 27, 2013, 01:40:13 pm »
It's also my understanding if you go any bigger then 30mm then you should probably get the valves done to accommodate the larger carb=more fuel.
« Reply #4 on: April 27, 2013, 02:33:03 pm »
I'd tend to agree with that.
