I just ordered Hagon Shocks from Dave Quinn this morning, I
Just wanted to double check...The Recomendation was for 90LB
I weigh 170 Lbs wet I believe Dave added 15 Pounds extra as I dont carry a passener to a total of 185 Lbs..
In California, I just ride normal roads and quite a few back roads,which are usually in good condition, I do the twisties once in a while and rarely go into the wilderness...
Just wanting to double check if I had the correct Fittings..and size.
Cheers
Mark
NB: reading Scottys write up and the instructions on getting off the top shrouds did help me in making my choice..Thanks Scottie and hopefully I will do that ride to Oregon soon and buy you that cup of coffee. or the Oregon Chai if you prefer.
