Turning the key results in a low buzzing, that's all. EFI seems to be working. Battery is not dead (accessories work, headlight seems normal). Panel appears to have normal power.
Does that mean I have a near-dead battery and the relay to the starter motor can't engage? Or does it mean I have a loose electrical connection in the starter circuit? Did I blow a fuse?
Bump-started the bike easily in 2nd gear and was able to ride normally to my next stop (it's parked outside my work). Assuming I can bump-start it again, I'll get it home.
Near dead battery is the first guess. Check its voltage - fully charged new battery is 12.8 volts.
More important is battery voltage when starting the bike. If it drops below 10.5V
during cranking of engine, then need a new battery. It may last a few more days if you keep charging it daily.
Or there may be a loose wire that formed full connection when you bump started it.
Turn OFF headlight before starting and later turn it on.
Sometimes the 'kill' switch can be on inadvertently (even though it does not appear that way). Flip it a few times and then try again.
Also was the NEUTRAL light ON ? The bike will not start even if the rear wheel rotates freely because the neutral circuit is still engaged. Move the gear lever slightly up or down till neutral light comes on.
Is your bike's side stand switch disconnected ? If not, it is good idea to do it.
Occasionally, the starter solenoid may get stuck. Smack it with the back of a screw driver to release it.
