If you just need something to get by for a bit get the same size automotive sealed beam halogen for about $10. There's a tab that won't line up (Moto bulbs have different tabs) but you can clamp it in just fine. And it will be way better than stock. Scott
Go 7" they are vastly superior to the 5 3/4" stock unit, seriously there is no comparison. Automotive 5 3/4" head lights are for four headlamp systems and come in two variety's; single filament high beam only and dual filament High/Low. The single filament high beam is obviously not useable for our purposes. We would think the dual filament Hi/Lo would be but the hot lick but such is not the case. In the Hi/lo bulb the brighter of the two filaments is the low beam. There used to be a 5 3/4' bulb that had our desired specs #4473 but it is no longer produced. My advice is to order a 7" and grab a replacement 5 3/4 from your R.E. dealer to tide you over till it arrives.
Has anyone tried the inner and outer rings from India that can be found on eBay? It looks like you can pick a set up with W clips for $25-$30 delivered... ..........
..........why US would be serviced with a 5.75"? ...........
