1914 Royal Enfield
February 08, 2016, 07:58:05 pm
Author Topic: 2003 bullet won't go into 1st gear  (Read 562 times)
Wojin
« on: April 23, 2013, 12:16:11 pm »
I recently changed the front sprocket on my 03 bullet.  After reasembly the bike would not go into first gear.  Prior to this it was also a little difficult, however now it won't go in at all.  I am hoping this is not a major fix.  Anyone ever have this problem before?
Re: 2003 bullet won't go into 1st gear
« Reply #1 on: April 23, 2013, 01:21:29 pm »
Can't say I've heard of that happening because of the sprocket change. However, Since the side cover was off, remove it again and check the tang/fork assy where the shift shaft comes through the cases from the shifter arm. It sounds like that is probably a bit off there and hitting the case wall between it and the sprocket.
« Last Edit: April 23, 2013, 01:37:04 pm by barenekd »
mrunderhill1975a
« Reply #2 on: April 23, 2013, 01:30:38 pm »
Does your 2003 have a four or five speed gearbox?  Is the shifter on the left or right side?
The Garbone
  • Shade Tree
  • User Complaints: 22
« Reply #3 on: April 23, 2013, 03:33:13 pm »
My first thought is clutch drag.  Does it shift with the engine off and rocking the bike? If so the clutch needs adjustment.  Just a shot in the dark....
Gary
57' RE Crusader 250
67' Ford Mustang
74' Catalina 27 "Knot a Clew"
95 RE Ace Clubman 535
01 HD 1200 Custom
07 RE 5spd HaCK
