copenhagen enfield
February 14, 2016, 05:18:31 pm
Author Topic: 08 Royal Enfield 500  (Read 870 times)
bitphire
« on: April 22, 2013, 05:33:31 pm »
Trying to replace the starter gear on the bike. Took the case cover off (forgive me if I use the wrong terms). I believe it's the primary chain (that wraps around the alternator? and clutch). We need to get the sprockets that are apart of the alternator off but it has a large nut holding it on and we can't figure out a way to keep the stuff from spinning on us. Any idea's on how to hold it so we can break that nut free? I can get some pics if need be.
Edit: can I assume this is a lefty loosy situation or is it reversed?
Edit2 Images:
We pulled that cover off and behind it is where the nut we need to figure out how to get off is sitting.
« Last Edit: April 22, 2013, 05:44:55 pm by bitphire »
bitphire
Re: 08 Royal Enfield 500
« Reply #1 on: April 22, 2013, 08:04:49 pm »
Update:
We managed to get it using a shirt and some wood shims to jam up the clutch sprocket enough for it to break free.
« Reply #2 on: April 22, 2013, 10:44:51 pm »
Some say she has a weird name but Necessity is the Mother of Invention. :)
bitphire
« Reply #3 on: April 25, 2013, 08:38:18 am »
Just a quick question, what oil do I put back in on this bike? The manual didn't come with and google is not treating me nice atm.
Thanks.
« Reply #4 on: April 25, 2013, 09:40:51 am »
Most people use regular motor oil, but Automatic Transmission Fluid also works very well.
bitphire
« Reply #5 on: April 25, 2013, 09:45:33 am »
Any specific weight? I read 20w-50 but they didn't mention for what year and it looked older than our 2008. Just curious what the manual suggests or if there is a more common option. I'm down in Central Texas so it gets pretty warm. Synthetic or non-synthetic?
« Last Edit: April 25, 2013, 10:39:55 am by bitphire »
boggy
  • Karma Ultra: 7
« Reply #6 on: April 25, 2013, 10:40:28 am »
I run 20w50 in my 2007 AVL, but I may switch up to ATF Type F next time I change it.
2007 AVL
2006 DRZ400SM
