Author Topic: Neutral from second gear weirdness  (Read 1546 times)
jedaks
on: April 18, 2013, 10:57:25 am
Hello all,
My 2004 5 speed had developed some strange behaviour recently. When I am coming to a stop and I downshift from 2nd gear and tap into neutral, the engine revs don't drop to idle speed. However if I downshift all the way to first gear and then tap up into neutral, everything is fine.
I assure you there are no air leaks anywhere around the carburetor or burrs on the throttle cable.  And the gearbox shifts smoothly into all gears, no clunks or grinding.
Any ideas?
walken4life
  • 2002 Bullet Deluxe
Reply #1 on: April 18, 2013, 02:06:07 pm
Almost sounds like it could be a false neutral.  Do you still have the LH Shift?  If so, could just be some sloppiness in the shift linkage.  That was my problem when I first got my bike.
Blltrdr
  • cycle-delic music
Reply #2 on: April 18, 2013, 03:27:51 pm
Yeah that sounds weird. Maybe your slide is hanging up a bit. Take off the air cleaner and verify that it slides up and down correctly. You also want it set so it faintly clicks/clinks when bottomed out.
2003 Classic 500 5 spd
2009 HD FLHT Police 103 6 spd
jedaks
Reply #3 on: April 18, 2013, 11:03:26 pm
Thanks for the help. Throttle slide is all good.
I'm wondering about clutch adjustment? Shifting is butter smooth.
The problem is not major because I can shift down to first and then up into neutral and all is good.
The gearbox a 5 speed left side shifter, so no linkages to worry about.
I've gone months without any hitches with the bike, so it must be my turn! ???
« Last Edit: April 18, 2013, 11:16:00 pm by jedaks »
baird4444
Reply #4 on: April 19, 2013, 05:35:07 am
points slipped, maybe closed up a little??
'My dear you are ugly,
 - Winston Churchill
