Hi everyone,
Just wanted to introduce myself. I'm located in the Washington, DC area and just got my bike (a 1987 rebuilt ex-Indian military 350cc) shipped from India, titled, registered, and tagged in the US. Now that the weather is getting nice and the bike is now street legal for me to ride, I wanted to add some additional performance features to make it safer on the highway (or safer in general) and get more power and speed. So far, I've added a K&N pod filter to my VM24 Mikarb, upjetted to a 105 main and 27.5 idle, installed a boyer bransden digital ignition, twist on external oil filter, and tachometer. While the bike works, i have had some hiccups along the road and I was wondering if anyone had any tips on the following:
-Boyer ignition doesn't make it easier for me to kick over the bike (my points ignition was more reliable). On my first test ride, a loose ground wire caused the bike to cut in and out of power forcing me to drift over to the side of the road, retighten the connection (it was grounded to the negative of my battery) and painstakingly kick the bike for minutes before getting the engine to turn over. I'm hoping this is related to the grounding wire/battery connection being loose, but does anyone have any tips on kick starting the bike? I kick it until a get compression, hit the decompression lever and press down the kick starter an inch or two (enough for me to hear a wheezing sound), return the lever, and kick...... and nothing.. try again...5 minutes later... try again.. engine finally turns over.
-At 3/4 to full throttle traveling around 45/50 mph the engine sputters and jerks a little, cuts out, and dies. I'm not sure if this is related to the boyer, or an overly rich/lean main/needle jet. Has anyone configured a Mikcarb VM24 with a K&N filter and can advise me on the jet sizes? More particularly, am I too rich or too lean, or is it some other problem?
-Bike idles around 2000 rpms. When I'm stopped at traffic lights, the RPM drops and threatens to stall out. I've become accustomed to this and just roll back a little on throttle to keep the RPM from sinking too low. Is this an idle jet issue, or an air screw issue? How can I adjust it to prevent it from stalling out at traffic lights (i can't for the life of me get it in neutral unless the engine is off).
In addition to all this, i was looking for more information on converting my engine to a fireball. Given that I have a 350cc engine, can anyone recommend somebody that can bore out the bottom end? Has anyone done this?
Anyway, thanks in advance for any advice/tips/words of wisdom. My fiance tells me that every time i go to work on my bike, I fix something and then break something else. This may be true, but I enjoy working on the bike... I just wish I could spend more time riding it without worrying about getting rear ended on the highway...
