My Bullet Finished At Last
27 Guests, 3 Users
PerazziMx14, JohnDL, mattsz
February 14, 2016, 04:16:35 am
Author Topic: Differences between the British and the Indian bullets?  (Read 3498 times)
REpozer
Re: Differences between the British and the Indian bullets?
« Reply #30 on: May 01, 2013, 04:00:46 am »
My Bullet with stock AVL engine,carb and exhaust , can easily make  125 kph ( 75 mph). I'm not a horse jockey either.
I change my dino diesel(15w-40) engine oil every 1000 miles. Not too concerned with oil break down.
REA # 84 ( the first time)
« Reply #31 on: May 01, 2013, 10:42:45 am »
Scotty, Are the replacement springs an exact replacement. If you got the wrong ones that could do it. Also you could loosen the tension on the chain that drives it. Just a pain in the ass to do taking the cover off it to do it. It may even free up just using the thing.  ERC
« Reply #32 on: May 01, 2013, 10:44:03 am »
Bike looks good did a great job on it.  ERC
« Reply #33 on: May 01, 2013, 11:20:38 am »
I forget who I ordered the springs from (someone on Ebay) but they were listed as the auto-advance springs for a Lucas K2F mag.  Like I said, sometimes it works great, other times it gets stuck.  Yesterday when I was riding, the few times I checked it, it was moving freely and seemed to be in working order.  Hopefully after a few more miles it will loosen itself up and not be an issue anymore.  I suppose that would make sense if the timing chain was too tight, but it did seem to be adjusted perfectly when I checked it.  Speaking of which, oil is constantly running over that advance unit via the timing chain running through the engine oil, correct?
« Reply #34 on: May 01, 2013, 12:23:23 pm »
Yes that will lube the hell out of it. Like I said it may be fine now.   ERC
