my beauty
February 13, 2016, 05:58:21 pm
Author Topic: chain adjustment with sidecar  (Read 923 times)
AwL
« on: April 11, 2013, 10:53:16 pm »
Hi - threads about chain adjustment for solo bike talk about 2" play with bike on centerstand.  What chain adjustments would folks suggest for bike with sidecar (tires on the ground)?  Just attached a pre-1989 California Companion sidecar on 2009 G5 - works a lot better than previous, heavier hack.   Thanks, Al
AwL
Re: chain adjustment with sidecar
« Reply #1 on: April 12, 2013, 10:34:11 pm »
Here's what the enfield with California Companion sidecar looks like.
« Last Edit: April 12, 2013, 10:44:15 pm by AwL »
« Reply #2 on: April 16, 2013, 01:40:24 pm »
With the rider on the bike the 1" play should be adequate.
dynamyt
  • So many bikes, so little time!!
  • I'd rather ride in thunder storms than go to work!
« Reply #3 on: June 09, 2013, 11:13:14 am »
Chain tension as a rule is 1" per foot (1/2" on center). I keep mine at 1" at the tightest point on the tension (driven) side of the chain (in our case upper or top side). In setting the tension, you should roll the sprockets and check the chain tension at all points if possible.
Ride Fast, Take Chances
Everywhere I go, there I am...
