Author Topic: Rear Axle Nut  (Read 2574 times)
raderj
  • Sgt Johnson USMC
on: April 11, 2013, 06:13:33 pm
Hey Everyone,
I did a search of the forum and found that the rear axle nut is 30mm. Or 31 according to another guy. This was in the "classic" bike section, though.
What is the axle nut size for the UCE? I need to order some sockets before I come home from Harbor Freight.
Thanks.
no bs
Reply #1 on: April 11, 2013, 06:28:37 pm
outer axle "castle" nut is 24mm. inner nut is 30mm.
raderj
  • Sgt Johnson USMC
Reply #2 on: April 11, 2013, 06:32:36 pm
Nice that was fast.
Fitting name, answer-giver.
Reply #3 on: April 11, 2013, 06:37:02 pm
Their large Metric Sockets set runs from 19mm-50mm. You will find everything you need in that set. I think it's on sale for about $58.00. It's a 3/4 drive and include a ratchet and breaker bar. If you grab the 20% off coupon out of a Cycle World or Motorcyclist magazine, they may honor it. They did on mine. The set was on sale last year for $25.00. It cost me $20. A 30mm socket by itself will probably be $25.00
no bs
Reply #4 on: April 11, 2013, 09:00:52 pm
unless you're ever contemplating the removal of old VW axle nuts, imho 3/4" drive sockets seem like overkill for our bikes. just sayin'.
Reply #5 on: April 11, 2013, 09:39:14 pm
Why would the bike care if it's 1/4" or 3/4"? It's not like you can't get an adapter to take them down to 1/2" or even 3/8" if you are so tempted. And since the ratchet and breaker is included, why not use them? And who says they are only going to be used on an RE?  When you got to that 47mm sprocket nut, you might be glad you have something that's almost big enough to break it loose. I used my fork tube extension to got my sprocket nut off! At least, I asn't worried about breaking a tool.
I've found the set pretty handy, actually.
no bs
Reply #6 on: April 12, 2013, 02:13:21 am
my concern is the socket's physical dimensions i.e. the opening chamfer. the nut's flats are not very wide and may tend to round over the edges. a 1/2" socket would provide a more secure purchase,having less chamfer. as to the primary sprocket nut, my ingersoll rand impact zips it right off.
Reply #7 on: April 12, 2013, 04:56:12 am
Hey Everyone,
Thanks.
 Mine is " size Crescent"  ;)
 ;D
Reply #8 on: April 12, 2013, 06:08:45 am
 ;D
Exactly!  I have a really nice Stanley adjustable wrench that I've used on every axle of every bike I've had in the last 6 years.
Reply #9 on: April 12, 2013, 08:07:40 am
took some pretty fancy positioning to get a crescent onto the axle and brake backing plate nut on my bike. I don't even think I got it to work.
bare
Reply #10 on: April 12, 2013, 01:07:28 pm
bare
Was that after you installed the aftermarket wheel adjusters?
jartist
Reply #11 on: April 12, 2013, 03:30:41 pm
I'm waiting for someone to invent a crescent torque wrench  :o
Craig McClure
  • Riding over 50 years
  • "No Future In Getting Old"
Reply #12 on: April 12, 2013, 04:38:06 pm
I was just complaining about not having a 30 mm wrench in the stock tool kit in another thread.
  I have a very complete socket set, but due to my upswept sporty exhaust, there is no room for a socket & handle.  I purchased an offset box end 30mm from GRAINGER for $6.95 .  Just the thing for my needs.
Best Wishes, Craig McClure
Reply #13 on: April 12, 2013, 06:35:20 pm
I need to get me a giant crescent for when I travel.  I think you need an 18mm wrench for the backing plate though, that's a tight spot.
Reply #14 on: April 12, 2013, 06:56:12 pm
Nah, it was mostly the brake arm, rod, and muffler setup, especially after I put the upswept on it. I could get straight in to the the nuts, but from the side was not gonna work. The front chain sprocket nut was also wasn't going to work with any other wrench than a socket. I could get a wrench on it at a bit of an angle, but it wasn't going to handle the torque.
A socket was, by far, the best tool for the job.
