Personally, I wouldn't want a straight thru silencer on my fuel injected RE.
When straight thru silencers are installed on a carburetored bike it always makes the fuel/air mixture run lean which causes the engine to backfire on deceleration. To correct this, larger jets are installed in the carburetor.
With a fuel injected motorcycle I believe there is a limit to how much the ECU can do to enrichen the fuel/air mixture if a straight thru silencer is installed.
When I installed the Harley silencer on my G5, I drilled a few holes thru the deflector plug to increase the exhaust flow and then rode the bike listening for the tell-tale backfire.
I continued this drilling and testing until the engine would just occasionally 'pop' on decel and stopped right there.
The spark plug shows normal colors after some 6000 miles of riding so I think I've got mine set just about at the limit.
I suppose a person could adjust the TPS (Throttle position sensor) to obtain a richer fuel mix but there is a chance of frinkling up the setting for other throttle positions.
