Home
Search
Calendar
Login
Register
Login
Register
Link 1
Link 2
Link 3
Link 4
Link 5
Unofficial Royal Enfield Community Forum
Royal Enfield Motorcycles
Bullet Iron Barrel
99 RE Timming cover
Login
Register
HITCHCOCKS SUPER BLACK FRIDAY EVENT
22nd NOVEMBER UNTIL MIDNIGHT 26th NOVEMBER UK TIME
SHOP NOW
10% OFF
EVERYTHING
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: 99 RE Timming cover (Read 1356 times)
velo499
Scooter
99 RE Timming cover
on:
April 05, 2013, 11:24:18 am
This years upgrade was supposed to be a new timing chest cover but alas I've waited to long , Nfield gear no longer carries them. My oil filter cover has a slow leak and there is a suspicious bump on the back end of the oil filter case. Any one notice this bump or is there another parts supplier to check out for the timing cover??? Thanks Mike
Logged
Grand Gearhead
World leaders in performance/racing Bullets
Re: 99 RE Timming cover
Reply #1 on:
April 05, 2013, 12:54:43 pm
I'd keep the one you have.
It's possible to repair slow oil leaks at a joint, and the "bump" is there on all of them.
Logged
ERC
Grand Gearhead
Reply #2 on:
April 05, 2013, 02:09:26 pm
You can check Hitchcocks and on-line Ebay. ERC
Logged
velo499
Scooter
Reply #3 on:
April 05, 2013, 02:13:13 pm
Thanks I'll do that, maybe a spare electronic ign module is in order, thanks again, that bump is out of the back of my brain. Must stay vigilante with the 99. Mike
Logged
Blltrdr
Grand Gearhead
cycle-delic music
Reply #4 on:
April 05, 2013, 04:39:40 pm
If you need a part other than what is listed on nfieldgear's webpage then you will need to call them to order.
I noticed the same thing you did on the end of the filter housing on the timing cover. It must be something that happens after the casting process. Mine had what looked like a JB Weld patch on the surface which seemed to weep a little. I'm not sure if they all come from the factory this way or if it is something that happens during the prep phase after the part is cast. I could see that if the cast wasn't quite perfect or they took to much of the flash off it would create a hole. The JB Weld was probably an authorized fix so they wouldn't have bins of F'ed up timing covers. It definitely is not enough oil loss to worry about. The new Enfield's leak oil minimally compared to the older ones.
Logged
2003 Classic 500 5 spd
2009 HD FLHT Police 103 6 spd
Print
Pages: [
1
Go Up
« previous
next »
Bullet Iron Barrel
99 RE Timming cover
Login
Welcome,
Guest
. Please
login
or
register
Have you missed your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
Login with username, password and session length.
