Factory 1999 325cc diesel
37 Guests, 7 Users (1 Hidden)
cstorckiii, oTTo, gizzo, MarkF, Gesewa, flyman
May 04, 2016, 12:25:16 pm
Author Topic: ScooterBob & GHG's C-5 Cafe Racer project  (Read 23725 times)
Re: ScooterBob & GHG's C-5 Cafe Racer project
« Reply #45 on: March 31, 2013, 08:07:43 pm »
GHG -
great to know the stock EFI can handle increased HP.  What pressure are you running the injection ?  also, is your regulator vacuum modified ?  stock injector -or- higher flow ?
    Yes it is Gremlin !  Stock fuel pressure.... 42 PSI.  Stock injector, with plenty left.  Fuel is regulated back to the tank using a Bosch/ VW Regulator. It has a range of adjustment on the Vacuum "Pub".
« Reply #46 on: April 02, 2013, 10:24:02 pm »
  Dyno sheet converted to and image............  D'oh !  I'm trying.... In the mean time, there is a download.
« Last Edit: April 02, 2013, 10:48:24 pm by gashousegorilla »
Alan LaRue
« Reply #47 on: April 03, 2013, 10:02:36 am »
That is BEAUTIFUL! Will it do the ton?
boggy
  • Karma Ultra: 7
« Reply #48 on: April 03, 2013, 10:08:22 am »
Here's the dyno sheet as an image, ghg.
2007 AVL
2006 DRZ400SM
« Reply #49 on: April 03, 2013, 10:31:48 am »
   EXCELLENT !! Thanks boggy you the man ! You know how long I played with that !? Not great on Cornputors.....
Quote from: Alan LaRue
link=topic=16128.msg175609#msg175609 date=1365001356
  It sure should !!
jartist
« Reply #50 on: April 03, 2013, 12:16:38 pm »
What a beautiful straight line- gotta love long stroke engines!  Very impressive work. It makes me wonder what scooterbob's cams alone would do for hp gains, unless the stock lifters can't handle the extra lift?
« Reply #51 on: April 03, 2013, 01:08:58 pm »
Removed
« Last Edit: April 03, 2013, 01:28:30 pm by barenekd »
« Reply #52 on: April 03, 2013, 05:04:11 pm »
   Yeah, these ARE are great motors ! And ScooterBob did some very nice work with the parts. Burned up a little cray matter on this one !  he..he..he.  And hopefully we both have a few more wrinkles in the brain. That's an interesting thought on the Cams with a stock head........... Certainly the valve train geometry would be looked at. Clearance issues and such.....
 I am sure SOME hydraulic lifters would work. I personally like solids for their consistency.  BUT, Hydraulics have been used for years successfully in Cars and bikes  for performance applications.
   You would also have to address the changes in air flow through the intake, it's effect on the map sensor..... If any.  Voltage readings the it's sending back to the ECU and etc.  Basically a new map would likely be needed. etc.....etc.....etc.  You can't just stick parts on..... intake, exhaust, Cams. And expect the stock ECU to adjust to these changes.... The ECU does have some learning in it, I believe. BUT to do it without thinking you will not have to make changes In the AFR's ?........... You may get away with it , with a filter or muffler?  But modern bikes come pretty lean from the factory.   So basically....... yeah, some things to look at.
« Reply #53 on: April 03, 2013, 08:03:51 pm »
OUTFREAKINGSTANDING! I've been wanting to see the finished bike for a long time.
Good on ya both.
« Reply #54 on: April 03, 2013, 08:14:07 pm »
IF my calculations are correct, it should show us about 112mph on the dyno .... which ought to be about the ton in real life. Gearing is still an issue - we just haven't haven't had the road time with all the new tuning to suss it out - but the power's there. REAL, honest to goodness Scheidler Steam Traction Locomotive power. Stay tuned .... I can't have the Crash Test Dummy riding in the cold!! Hahahaha!
« Reply #55 on: April 03, 2013, 08:42:01 pm »
Good on ya both.
    DANO' !!!!  How ya been man !  How's the back doin'?!  Thanks ! Looks kinda Crazy, aye ?! Went deep in the depths of the Garage for a while and I haven't emerged !
« Reply #56 on: April 03, 2013, 08:57:41 pm »
   Probably not far of the mark with that !!  :o
« Reply #57 on: April 04, 2013, 05:04:10 pm »
Any possibility of getting a pair of ScooterBob cams for the UCE ?
Or, even the profiles ?
2002 BMW R1150RT-P
« Reply #58 on: April 04, 2013, 06:47:09 pm »
If all this works out well after a little testing, I may grind a few more sets .....
« Reply #59 on: April 05, 2013, 01:37:06 pm »
I just checked into this thread again, and
WOW,
you guys really did a lot of work on this thing.
It not only has the looks, but it has the "GO" to go along with it!
Congratulations on a real nice result!
When we finally get our B5 done, maybe you and Chumma can go out and wake up some sleepy suburban NJ towns some week-end with some Royal Enfield UCE Thunder!
 8)
« Last Edit: April 05, 2013, 01:46:07 pm by ace.cafe »
