2009 Military
40 Guests, 1 User
gizzo
February 11, 2016, 05:05:06 am
Author Topic: Bullet G5 as first motorcycle  (Read 2988 times)
Re: Bullet G5 as first motorcycle
« Reply #60 on: April 13, 2013, 10:35:31 pm »
IMO, with only 350 miles on it, it hasn't even begin to break in.
Speeds like 65 (or 55 if you prefer) mph shouldn't even be tried for a little while.
These iron barrel engines were designed back in the 1940's and haven't changed greatly.
They require "old fashioned" break in periods to allow the moving parts to gently rub off the tight areas and the high spots.
