1968 Rebuild
May 28, 2016, 03:59:40 pm
Author Topic: Crank Shaft Roller Bearing 350cc CI.  (Read 735 times)
arindamcc
« on: March 27, 2013, 11:41:46 pm »
I want to change both roller bearing of my bullet model 350cc STD Indian bullet.Please suggest me a pair of good bearing stock bearing are not high quality.I am running stock crank.Bellow the list of my choice.
1a. FAG NU205E-M1-C3  @ $122 from Amazon
2a. FAG NU305E-M1-C3  @   $112 from Amazon
2a. NU205MY Nachi CN   @ $64 from VXB
2b. NU305 Nachi CN       @ $31 from VXB
did not find NTN bearing on any online shop.
Re: Crank Shaft Roller Bearing 350cc CI.
« Reply #1 on: March 28, 2013, 06:13:52 am »
The FAG models you picked are the top of the line, and have the correct C3 clearances.
I'd suggest them.
The Nachi will get you by, but the clearances are normal and not C3, and Nachi is not at the same level as FAG.
However, both brands are good bearings.
I'd look for the Nachi in C3 clearances, for the best price, and assuming it's just for normal street use. For high performance use, I'd suggest the FAG.
arindamcc
« Reply #2 on: March 30, 2013, 10:47:03 pm »
Thanks ACE for your valuable reply.Now please tell me which bearing are best for gearbox (I am want to use 90w gearoil in gearbox), both side shielded or one side shielded and C3 clearance or CN  clearance.
