Retro Rocker
20 Guests, 3 Users
pearcey2, Ice, Blltrdr
February 09, 2016, 12:23:46 am
Author Topic: Real wheel Spokes  (Read 848 times)
bobbypin09
Real wheel Spokes
« on: March 23, 2013, 03:24:10 pm »
Hello People,
I am the new owner of a 2003 Royal Enfield Bullet 500.  when I got the bike I noticed it had 6 spokes missing in the rear. So i ordered some new ones from nfieldGear.com  When I received them and tried to have them installed. I noticed that they are shorter then my original spokes that were on before.  So I did some research.  The spokes that I ordered from nfieldgear say RR wheel spokes (inner) yellow and (outer) green Part No. 143790 & 143792.  Then I noticed that there are some on ebay with a part number 141135 & 141136 that are also for the real wheel.
what the hell does the "RR" mean, and did I get the wrong ones??
any information would be great!
Re: Real wheel Spokes
« Reply #1 on: March 23, 2013, 04:17:40 pm »
Sounds a bit like you got the wrong ones, but the part nos look right. What size rear wheel does your bike have. Did someone slip on a 19" one?
Have you called NFG about them?
« Last Edit: March 23, 2013, 04:21:03 pm by barenekd »
t120rbullet
« Reply #2 on: March 23, 2013, 05:39:09 pm »
Your bike should have a 19" wheel on it.
The spoke #s you have are correct. The other set of #s you found are the old #s and are also correct.
My old parts list (95) has them listed as 141136 (dust cover side,outer) that # is now 143792 in the new book.
The other one is # 141135 (drum side,inner) and that # is now 143790 in the new book.
CJ
« Last Edit: March 23, 2013, 08:39:26 pm by t120rbullet »
« Reply #3 on: March 23, 2013, 06:01:05 pm »
bobbypin09
Does "shorter" mean they are too short to engage the nipples by at least 1 diameter or does it mean they don't run almost all the way down thru the nipples?
If a thread has an engagement of one or more thread diameters it is strong enough to do the job.
motomataya
« Reply #4 on: March 23, 2013, 07:26:03 pm »
With good hardware one and a half bolt diameter is the ideal engagement. This is not nearly enough for the rolled threads on spokes. They need to go almost through the nipple.
