I know the LED issues have been discussed a lot on here, but I can't find a solution to mine. I switched over all of my lights to LEDs from Superbrites on my 2010 C5, including a LED flasher unit. When I have any signal flashing, the opposite blinks dimly, and so does the flash indicator on the speedo. So, I grounded the indicator housing and it takes away the opposite dim light when the right side is flashing. However, with the grounded indicator housing and then flip on the left turn signal it blinks all the lights, or creates a spark on the grounded indicator. I'm figuring something is crossfeeding or there is a ground issue somewhere. I did put 150 ohm resistors on each signal, as discussed on another thread on here to get them to work in general. Any help on this would be greatly appreciated! Thanks!
