IMO, from an electrical
contact point of view, soldering wiring terminals on is a good thing.
From a
long lasting point of view, soldering can lead to failure of the wire at the connection.
Even if a rosin core solder is used as it should be for electrical connections, the solder keeps the individual strands in the multi strand wire from moving freely as the wire is bent or moved. This can introduce unwanted stresses into the wire.
The solder also creates an exact place where the multi strand portion ends and the soldered "solid" place starts which concentrates the stress at that location.
Copper is one of the metals that hardens when it is bent and if this bending (like vibration causes) is repeated the wire can become brittle.
Rather than bending, brittle metal breaks.
I'm not saying this will happen to anyone's newly installed connector but it is something to keep in mind.
