Rich, learn to push start it. Key on, ignition on, put it in second gear and pull in the clutch. Now get it moving: roll down a hill, push from a friend, or push next to it. Once it's rolling get on the seat and let the clutch out gently. The turning wheel will force the engine to turn and should get it started. As soon as it starts pull in the clutch and give it a little gas to get rolling.
This is all fine to a point. When you've jumped on the bike and are ready to drop the clutch, stand up and drop your butt on the seat as you drop the clutch.
If you don't, chances are real good that the rear wheel will just lock up! Then you have to start over and do it all again!
This was a starting technique used by road racers in the old days. (that's before the '80s). They called it bump starting. As the rider came to the starting grid, he'd put the bike in second gear and then back the bike up so the piston was backed up against compression. If the bike had a manual compression release, he could use that to unload the cylinder. Two strokes didn't generally have this option. This gave the piston some free movement when the rider started pushing. When the flag dropped the riders started pushing there bikes. they usually only took 3 or four steps and jumped on side saddle and popped the clutch as they hit the seat. The bikes hopefully started, and they got on properly. If it didn't start, they were in a position to get off and continue pushing.
Had a lot to do with why I never got into road racing, until much later!
