2009 AVL Bullet Classic
28 Guests, 5 Users (1 Hidden)
Grant Borden, Under The Redwoods, ace.cafe, Hondo
May 04, 2016, 08:03:55 pm
Author Topic: Thar She Blows!!!  (Read 2332 times)
Adrian
Thar She Blows!!!
« on: March 18, 2013, 05:18:04 pm »
No, not the Great White Whale, how about an iron Bullet decompressor retro-fitted to a 500 AVL head? Not possible, so it had to be done.
Pictures first:
URL=http://imageshack.us/photo/my-images/209/dcv3.jpg/][/URL]
URL=http://imageshack.us/photo/my-images/836/dcv4.jpg/][/URL]
Basically you drill and tap for a 14x1.25mm spark plug thread opposite the existing spark plug. Some of the finning between the rocker boxes has to go, but with a milling machine and some careful work (rather than my butchery of an innocent component) you could sacrifice a lot less. I am informed by a UK Bullet specialist that subsequent overheating should not be a problem here in NW Europe as the sheer size of the rocker boxes mean they conduct enough heat away already, not so sure if that holds good for the Southern States of the USA or India, though!
More details if anyone is interested.
Regards,
Adrian
DanB
Re: Thar She Blows!!!
« Reply #1 on: March 18, 2013, 05:31:01 pm »
Oh, now that's cool!  Thanks for sharing.
2006 AVL Electra
« Reply #2 on: March 18, 2013, 05:39:36 pm »
Well, that should get the attention of the crowd at the local Drive In Restaurant if you use it to kill your engine.
Thump, thump, thump, thump, CHOOF, CHOOF, CHOOF.  ;D
bobscogin
« Reply #3 on: March 18, 2013, 06:30:39 pm »
Adrian, I was going to add the Iron Barrel decompressor to my AVL, then got curious as to whether or not the existing valve lifter could be utilized in some manner. I bought an Iron Barrel decompressor lever and hooked the AVL cable to it and it lifts the valve with ease. Is there a down side to that method?
Bob
« Reply #4 on: March 18, 2013, 08:53:12 pm »
Glad to see some one take the plunge and make it happen.....AWESOME !!
 There was an AVL twin spark produced for the domestic Indian market so we knew adding a I.B. de-comp was do-able but till now no one I know of had actually done it.
Congrats !
« Reply #5 on: March 18, 2013, 11:02:50 pm »
Looks like a clean job, Adrian.
Should work great.
Thanks for the nice pics too!
jartist
« Reply #6 on: March 18, 2013, 11:22:49 pm »
Great job- that's an awesome setup and execution!  I'd love to do the same on my uce.  Where did you get the parts?
« Reply #7 on: March 19, 2013, 01:42:38 am »
Standard de comp valve for an Iron Barrel engine.  ;)
AVL Power!
« Reply #8 on: March 19, 2013, 02:20:55 am »
Yet another awesomeness!
Adrian
« Reply #9 on: March 19, 2013, 07:59:45 am »
Thanks for the encouraging comments, folks. It's a good job those pictures aren't TOO detailed...
If nothing else it has persuaded me to buy a bench drill after I messed up the pilot hole for the 14mm thread, fortunately it all cleaned up OK with an insert kit  :-[ You also need a 7/8" drill to counterbore the hole to get the bottom of the decomp valve at the right height (depth?).
The whole point of this was since my AVL project is K/S only and Bullet Whisperer did a good job with the valves, starting could be easier. The original AVL valve lifter also cannot be used with the "S" cams. The only downside apart from extra maintenance is the loss of cooling fins to the head, which can be minimized by careful use of a vertical milling machine.  You'd have to decide if it was an acceptable risk or not for your local riding conditions.
Regards,
Adrian
JVS
  • I love chicken
« Reply #10 on: March 19, 2013, 08:03:20 am »
I still wish the UCEs had the manual decompressor. Would've been so much fun. Not sure if the same thing is possible on a UCE. Drill, manual decomp in. Auto out.  :o
jartist
« Reply #11 on: March 19, 2013, 09:53:59 am »
It should be easier with the uce because there's already a spot for one in the casting on the head on the right side. I will probably get a machinist to do it tho- I don't trust myself to get the hole straight.
« Reply #12 on: March 19, 2013, 10:12:17 am »
There are easier ways to do a decompressor on the UCE.
A properly located Harley-style decomp is able to be installed unobtrusively, and we have done this with several Iron Barrel heads which were converted to twin-plug ignition.
jartist
« Reply #13 on: March 19, 2013, 08:16:56 pm »
Where does the harley style decompresser go? I thought about one of those but the well for the "second spark plug" (for lack of a better description) looks too deep to get your fingers in to reach the release button.
« Reply #14 on: March 19, 2013, 10:48:50 pm »
Will wonders never seize?  :o
I always figured Hardly just "holed" their piston to release its compression.
Who knew they might have a device to accomplish the task?  :D
