Black Canyon -Oh so nice!
May 05, 2016, 06:53:43 pm
Author Topic: Wire Routing - What works best?  (Read 576 times)
DanB
« on: March 16, 2013, 11:45:10 pm »
Recently been having some electrical problems; turn signals were grounding out.  I pulled the tank and found the wire harness had been pinched by the engine stay (result of someone else working on my bike, grrr!).  See below, after i pulled back the insulation and amputated.  I soldered in a replacement and sealed it all up with heat shrink and then tape.
With the tank off, i noticed grommets on the 2 harness and the 'hooks' on the tube.  Are these grommets to be placed in the j hooks?  Mine arent, and it appears i may have too much wire from frame to the nacelle.  What have others done?  I figure nows the time to fix it.
2006 AVL Electra
Adrian
Re: Wire Routing - What works best?
« Reply #1 on: March 17, 2013, 09:45:22 am »
Hi Dan,
You need some slack in the wiring loom to allow the forks to turn without stressing it. There are some factory pressings in the gas tank front mounting bracket for the wiring to slot in.
Note that the wiring around the steering head may fail anyway with age/use, I had the battery to ammeter as well as turn signal wiring break, the bike is getting on for 8 years old.
Regards,
Adrian
DanB
« Reply #2 on: March 17, 2013, 10:10:32 am »
Thanks Adrian. That makes sense. I've found several areas that have rubbed thru insulation. It's those rubber grommets on the bundles I can't figure out. Just going to ignore them, as they make no sense to me.
2006 AVL Electra
