Oil Cooler partly installed
May 29, 2016, 04:17:35 pm
Author Topic: Hardtail 612  (Read 1925 times)
Hardtail 612
« on: March 15, 2013, 06:06:08 pm »
Here's my latest project. Hardtail frame, left shift 5 speed, kick start, 612cc motor, front fender on rear, etc.  Hope I can load picture not to good at that.   ERC
Re: Hardtail 612
« Reply #1 on: March 15, 2013, 06:30:28 pm »
Very cool!  Frame looks pretty clean.  Does it run?
Re: Hardtail 612
« Reply #2 on: March 15, 2013, 06:50:29 pm »
I hope so when I'm finished. This is the first single I've done, all the others were old twins.  ERC
da punds
  • Fireball 25
  • One of Britain's most northerly Bullet fans
Re: Hardtail 612
« Reply #3 on: March 21, 2013, 02:36:54 pm »
Nice looking bike, I love the colour. I went the 612 route but now heading down the 535 Fireball route.
Heres mine :
56 Trailblazer Gemini, Super Fireball BigHead, 59 Clipper 570, 39 Model CO + others(BMW, GasGas, Yamaha, Suzuki (rare GSXR-750R)), Mk1a Interceptor project.
Re: Hardtail 612
« Reply #4 on: March 21, 2013, 02:58:36 pm »
Heres mine :
You did try the Ace Piston and cams on your 612 , didn't you ? How did that work ? Are you planning on using the Ace big head on the fireball ?
Re: Hardtail 612
« Reply #5 on: March 21, 2013, 04:11:25 pm »
da punds, Are you building another or weren't you satisfied with the 612 and are scaling down to the 535?   ERC
da punds
  • Fireball 25
Re: Hardtail 612
« Reply #6 on: March 21, 2013, 04:18:56 pm »
 1 Thump Yes I did, the cams and piston worked well, the downside was the motor does not rev too well, so the upper rpm cause lots of vibration, and not much increase in power. I am in the process of having Tom work on the BigHead, initial flow figures look very good, I am still waiting for completion on the head as I have elected to go for a rocker job too. Cant wait to get it back on the road and give it some ....... :-)
ERC I am scaling down, looking for more top end than before, 612 was a great cruiser but wanting to go scratching, I have reduced my collection and got rid of 2 of my gsxr's which got the boy racer stuff out of my system. So the Enfield has to fill that roll.
Re: Hardtail 612
« Reply #7 on: March 21, 2013, 06:59:58 pm »
Your bike looks great. It will be interesting to see how the one I'm putting together runs. The seat you have is it comfortable? I have a similar one, put it on didn't like it when I sat on it so I made up some brackets and put a foam filled one on.  ERC
Chuck D
Re: Hardtail 612
« Reply #8 on: March 22, 2013, 07:56:17 am »
Heres mine :
Wow! That bike is an absolute stunner.
Chuck D
Re: Hardtail 612
« Reply #9 on: March 22, 2013, 07:59:25 am »
Love the colors! Very playful. Please keep us updated on your progress.
da punds
  • Fireball 25
Re: Hardtail 612
« Reply #10 on: March 22, 2013, 09:29:39 am »
The seat is quite comfortable, it is nicely run in now, although I am planning to change it this build for a large Bates model, (gel/foam filling), I was hoping to loose an inch in seat height and make the reach to the bars slightly longer, thus reducing my frontal area. I think I might be taking this tweaking stuff a bit far ,,, LOL
Re: Hardtail 612
« Reply #11 on: March 22, 2013, 10:54:12 am »
Is that a triumph instrument cluster. Could you post a close up of that. Thanks.
da punds
  • Fireball 25
Re: Hardtail 612
« Reply #12 on: March 22, 2013, 12:23:05 pm »
The instrument mount is from an Interceptor I think, the yokes are Hitchcocks, the mounting points match up perfectly.
Re: Hardtail 612
« Reply #13 on: March 22, 2013, 03:54:37 pm »
I like the way your drag bars clear the tank with ease. Thats just not possible on the stock casquette setup without reducing the turning radius.
Re: Hardtail 612
« Reply #14 on: March 30, 2013, 11:15:56 pm »
ERC - How are you coming on the hard tail?  Have you got it it started yet or do you plan on rebuilding the motor?
