So I'm fairly new to RE's and I've figured out why the headlamp switch doesn't work, but in doing so I found a couple of connectors in the left hand fuse box that I'm trying to figure out what they are/do. One is a 6 pin connector, with 3 pins actually connected to wires and the wire colors are red/white gray and black. The other is a wire coming off of the large connector harness and it's had a green sheathed female single plug connector attached to it.
