baby in makin 4
February 07, 2016, 10:48:26 pm
Author Topic: 7" Halogen Headlight  (Read 1540 times)
PaulF
« on: June 04, 2008, 09:52:13 am »
Does there have to be an upgrade in any part of the chrging system to accomodate a 7" halogen headlight or will it be just a plug&play?
Thanks,
EnfieldJake
Re: 7" Halogen Headlight
« Reply #1 on: June 04, 2008, 10:08:00 am »
For my '06 Electra it was plug and play without any issues. For reference, I'm using a Sylvania Silverstar sealed beam halogen
« Last Edit: June 04, 2008, 10:10:28 am by EnfieldJake »
Bankerdanny
« Reply #2 on: June 04, 2008, 01:58:39 pm »
It was plag and play for my standard Bullet too.
And a VERY worthwhile upgrade.
Endeavor To Persevere
PhilJ
« Reply #3 on: June 04, 2008, 02:17:40 pm »
Thanks,
Which model RE to you have? If it's an older model there could be a problem as the alternator doesn't have a very high output.
PaulF
« Reply #4 on: June 04, 2008, 02:49:47 pm »
Thanks,
So I wasn't imagining things. I thought I had read somewhere about a regulator/rectifier or alternator upgrade and wanted to confirm that, thanks.
Its and 08 AVL motor so I guess I'm good to go.
PhilJ
« Reply #5 on: June 04, 2008, 03:50:15 pm »
Oh yes. Mine is too and I put T-Bar head lamp in mine. All works well.
Good Luck.
scoTTy
« Reply #6 on: June 04, 2008, 10:54:10 pm »
blue dot  here 2.. also  turned off the light when starting
