Mt. Ord
February 09, 2016, 11:03:34 pm
Author Topic: Aftermarket Speedo And Tach???  (Read 693 times)
« on: March 10, 2013, 11:12:08 pm »
I want to replace the speedometer and tachometer on my 58 Trailblazer.  They are 3 1/4" gauges and I'm hoping to find something with white faces and black or red numbers, or reverse of that if white faces aren't available.  The tach needs to be and electric input so I can hook it up to Thorspark ignition I'm going to be installing.  The speedo I want to be able to hook up to the factory cable.
Any help finding these would be greatly appreciated.  Thanks!
ERC
Re: Aftermarket Speedo And Tach???
« Reply #1 on: March 11, 2013, 06:31:33 pm »
The ones that fit the new Bullet fit but you have to change the cable. They sell them on ebay that are longer and fit the new speedo. Tach you can find on the web.  ERC
