2011 B5
25 Guests, 0 Users
May 28, 2016, 03:06:56 am
Author Topic: Thunderbird AVL350 Enginer Missfiring  (Read 631 times)
anoop.kp
  • Tunderbird AVL350
« on: February 23, 2013, 07:14:49 am »
Hi,
I have a 2008 Model Thunderbird AVL350 , i have driven this about for 65k. Recently i am facing a misfiring (odd thump/ Pulling back) problem in the engine. When i raise the vehicle rpm more that 2k the engine will start misfiring or it gives an odd thump sound or a feeling like the vehicle is pulled back whatever we call it. I have given it to my regular mechanic and he said it is an electric problem and he changed the pick up coil, main coil and battery and etc. nothing worked out and the problem remains the same. if  any body has any idea about this issue, pls share.
Anoop
AVL Power!
Re: Thunderbird AVL350 Enginer Missfiring
« Reply #1 on: February 23, 2013, 08:24:16 am »
Anoop Ji, Welcome to CMW forums!
When I changed my carb for the first time, I had issues with my jets. Well it was due to over-riching and faced something similar, felt like as if the bike was de-accelerating after certain RPM. Got the jets fixed and it was all good.
Did you check your Airfilter? (Maybe it is clogged and restricting air flow)
-Sanket
anoop.kp
  • Tunderbird AVL350
« Reply #2 on: February 26, 2013, 12:49:20 am »
Hi.. Sanket Ji...
I think you are right this has started when i have changed my carbs , let me check th jets. Will update soon..
Thanks
Anoop
Anoop
AVL Power!
« Reply #3 on: February 26, 2013, 04:00:26 am »
Ahah! You should have mentioned that :)
By the way, which carb are you using at moment? And what are the jetting specs?
-Sanket
« Reply #4 on: February 26, 2013, 11:30:18 am »
Just a  bit of advice. Any time you have a problem, check the last thing you worked on first!
