Royal Enfield WD/CO/B
February 11, 2016, 05:48:43 pm
Author Topic: Oil getting to the points?  (Read 548 times)
solg
  • /Users/solgualtieri/Desktop/165532_489778052839_61
« on: February 16, 2013, 08:43:36 am »
I have a 2008 iron barrel. I have removed the crankcase breather catch can pluged the hole at the timing chest & rerouted the line to the back of the bike.
In my Snidal manual (pg 204) it mentions replacing the CB shaft oil seal to avoid "oil getting to your points ". Should I have done this.
Time flies like an arrow
Fruit flies like a banana!
Re: Oil getting to the points?
« Reply #1 on: February 16, 2013, 09:00:22 am »
Only if you are seeing oil getting to the points.
If the points are dry, then the seal is working the way it should.
solg
« Reply #2 on: February 16, 2013, 10:31:30 am »
When I replaced the points with a Power Arc I did notice a slight amount at the back inside the distributor. Not much though.
« Reply #3 on: February 16, 2013, 11:51:22 am »
a little seepage was the norm back in 2003 when I bought mine.
The best fix was to drill a 3/16 "weep hole" in the bottom
of the cap to prevent it collecting in there and fouling the points.
             - Mike
solg
« Reply #4 on: February 17, 2013, 07:12:25 am »
Thanks for the input fellas. Guess ill just keep an eye on it
