Author Topic: General Questions  (Read 1060 times)
Darvin Jahnke
on: February 14, 2013, 02:28:41 pm
OK guys here come the questions. When was the first year for the UCE engine and the first use of efi? Also what is the AVL engine as compared to earlier engines? Thanks.
TWinOKC
Reply #1 on: February 14, 2013, 03:23:28 pm
2009 was the first year of the UCE and also first year for EFI.
2009 was also the last year of the AVL.  RE are subject to change any time of the year.
AVL has an aluminum jug, older models were iron.
May not be exactly correct on everything but others will comment if I am off a little.
2010  C5  Teal
2011 Triumph Bonneville T100
2015 Scrambler Ducati
Darvin Jahnke
Reply #2 on: February 14, 2013, 03:42:12 pm
Thanks for the reply. When did the AVL replace the iron cyl?
TWinOKC
Reply #3 on: February 14, 2013, 04:04:49 pm
2006 maybe
« Last Edit: February 14, 2013, 04:12:05 pm by TWinOKC »
2010  C5  Teal
Reply #4 on: February 14, 2013, 10:45:59 pm
The AVL was a Swiss re-engineered engine intended to meet some of the worlds emission standards.
In doing this they replaced the old iron barrels floating sleeve bearing on the big end of the rod with a roller bearing.  They also changed the aluminum con rod to steel and replaced the old reciprocating twin piston oil pump with a gear pump and modern paper oil filter element.
The ignition was also updated to a CDI.
The UCE's inherited most of these changes with the oil pump becoming a gerotor style.
Roller type hydraulic valve lifters, automatic compression release,  and fuel injection were added along with a beefier electric starter sprag clutch.
Most of us have found this new UCE engine to be reliable and for the most part, trouble free.  I have over 8500 miles on my G5 and several of our members have over 15,000 without any problems.
The chain and a lack of proper protection from sharp metal edges for the wiring harness seem to be the only areas that could be improved.
Darvin Jahnke
Reply #5 on: February 15, 2013, 01:05:14 am
That information is very helpful. Thank you.
