End of the Road
43 Guests, 1 User
JohnDL
May 30, 2016, 05:50:50 am
Author Topic: what position should the mag retard lever be in when starting the bike?  (Read 1792 times)
'45 WD CO
  • '43 WD Enfield
  • 2006 Bullet 500 Deluxe and 1943 WD CO
what position should the mag retard lever be in when starting the bike?  Thanks.  Bill
Re: what position should the mag retard lever be in when starting the bike?
« Reply #1 on: February 07, 2013, 08:35:26 pm »
I can't say for certain about magnetos, but generally the ignition wants to be retarded for kicking over, and then advanced when you begin to ride.
'45 WD CO
  • '43 WD Enfield
« Reply #2 on: February 08, 2013, 07:55:42 am »
Thanks ace.  Do you know which direction on the lever retards the ignition?
mrunderhill1975a
« Reply #3 on: February 08, 2013, 10:12:19 am »
I don't know for sure on your bike, however,if you look closely at the lever mechanism, you should be able to see how the lever pushes the mechanism.  The retard would be in the direction that causes the mechanism to move in the same direction as the magneto rotates.
mgm
  • 2009 AVL Deluxe
« Reply #4 on: February 08, 2013, 10:16:56 am »
Okay, I gotta ask a stupid question. Does an 06 iron barrel have a magneto...or a retard lever?
Chuck D
« Reply #5 on: February 08, 2013, 11:12:32 am »
http://www.enfieldmotorcycles.com/forum/index.php/topic,15852.0.html
« Reply #6 on: February 08, 2013, 01:41:53 pm »
An 06 should have an automatic advance built into the points plate.
They do not have magnetos. Mags pretty much went away in the 50s, with a few bikes hanging on into the 60s. Along with the mags, manual retard levers went away went with them. So did holed pistons.
« Reply #7 on: February 08, 2013, 01:44:42 pm »
He's asking because he has a 1945 Royal Enfield WD-CO
72westie
« Reply #8 on: February 09, 2013, 09:31:08 am »
I think it would be less confusing if there wasn't 4 threads asking questions about the same bike.  ;)
2001 Royal Enfield Bullet 500 Race Bike:
2008 Ahrma Classic 60's #1 Plate
2009 AMA Vintage 50's #1 Plate
2010 AMA Vintage 50's #1 Plate
http://www.bgmotorcycle.com
ERC
« Reply #9 on: February 09, 2013, 12:20:08 pm »
If it's still mounted on the left handlebar you pull the lever counterclockwise towards you. The choke lever which should be on the right handlebar pull that towards you which when viewed from above goes clockwise to choke it. That's if it's set up original if not it's anybodies guess.  ERC
'45 WD CO
  • '43 WD Enfield
« Reply #10 on: February 15, 2013, 05:10:30 pm »
Thanks ERC.  Yes, all the controls are still where they originally were.  Just replaced the battery, and obviously have a problem with the horn switch, because I can't turn it off!
SRL790
  • 1954 350
« Reply #11 on: February 21, 2013, 12:12:47 pm »
Bill,
Where you need to set the lever will depend somewhat on where your ignition timing is set at.  On mine I generally start with just less than full advance and most times it starts.  If it kicks back on you retard it more by pulling the lever toward you.  Experience (and your ankle) will tell you where the best position is.  Retard it too much and it won't fire.
Important!  Not sure what your experience is with kick starting engines but always place the ball of your foot on the kickstart not the convenient right angle made by the the sole and the heel of your boot.  This way if it kicks back your ankle should have enough flex to absorb the shock.  Even a lowly 350 can kick back with suprising violence.
Andy
Andy Wiltshire
'45 WD CO
  • '43 WD Enfield
« Reply #12 on: February 21, 2013, 01:20:55 pm »
Thanks Andy!  Very helpful!  Fortunately, my 06 Iron Barrel has electric start problems, so I've been kick-starting it for years now.  I like the tip about the ball of your foot.  Cheers,  Bill
