Royal Enfield
46 Guests, 2 Users
fnmlsw, Rattlebattle
May 26, 2016, 03:54:04 am
Author Topic: Battery for a '45 WD Enfield?  (Read 716 times)
'45 WD CO
  • '43 WD Enfield
  • 2006 Bullet 500 Deluxe and 1943 WD CO
« on: February 06, 2013, 12:59:59 pm »
Does anyone know a good replacement 6 volt battery for a '45 WD Enfield?  It would be easiest if it were in the US.  Thanks,  Bill
72westie
Re: Battery for a '45 WD Enfield?
« Reply #1 on: February 09, 2013, 09:34:29 am »
6 Volt? Whats the size of the battery box? I think some companies make sealed batteries now in 6v, but a conventional wet cell is what it came with.
http://www.bgmotorcycle.com
72westie
« Reply #2 on: February 09, 2013, 09:43:21 am »
From Hitchcock's site:
LU/54028423    BATTERY 6v (DRY) 121 x 61 x 131mm Redditch models after 1958 19.50
I assume the unavailable one is prior to 58?
LU/PUZ7E    BATTERY 6v DRY 120 x 90 x 160mm Blk Exide type Redditch mods
If that one is about the right size, 4.7" long, 3.5" wide and 5.1" high, a Yuasa 6n6-3b-1 should work. Its a 6 amp hour, 6 volt battery, its 3 7/8" Long, 2 1/4 Wide and 4 3/8" High
'45 WD CO
  • '43 WD Enfield
« Reply #3 on: February 15, 2013, 05:12:11 pm »
Thanks.  Got it and all is well (if I could now get the horn switch to shut the horn off!)
