Royal Enfield
February 12, 2016, 05:02:17 pm
Author Topic: 1945 WD Enfield resoration project  (Read 658 times)
'45 WD CO
  • '43 WD Enfield
  • 2006 Bullet 500 Deluxe and 1943 WD CO
« on: February 03, 2013, 01:05:59 pm »
I JUST enherited a '45 WD Royal Enfield in almost perfect shape!!!!  It last ran 10 years ago, and then was emptied of all her fluids and stored away in a garage.  Do I need to take certain first cautious steps to get her running, other than the obvious of adding fluids and a new battery?
Thanks,  Bill
Re: 1945 WD Enfield resoration project
« Reply #1 on: February 03, 2013, 04:29:48 pm »
Cool find!  If it was completely untouched and dry of all fluids for 10 years, you should pull the sparks out and put an ounce or so of motor oil into the cylinders and let it soak for a day or so.  Then very slowly kick it over for a while.  This will prevent cylinder damage if the piston rings have seized inside the motor.
You might also need to replace the gaskets and seals on the carb as they tend to dry out and leak from sitting for too long.
gunnerasch
« Reply #2 on: February 04, 2013, 03:34:35 am »
Get a pint of Marvel Mystery Oil and put a couple ounces in each cylinder and as the gentleman said...slowwwly kick it over, let it sit for 15 minutes..and do it again..and then again in another 15 minutes and then let it stand for a day or so. He is correct..this will help free up any rings, lube the cylinder walls and so forth.  Enjoy!
'45 WD CO
  • '43 WD Enfield
« Reply #3 on: February 04, 2013, 10:38:36 am »
Terrific advice. Starting with the oil tonight.  Thanks! Bill
