rally on the river
46 Guests, 3 Users
voodoochild, Ice, kodai
May 24, 2016, 10:24:15 pm
Author Topic: '99 DeLuxe,10K miles...turn signals not working...WTF?  (Read 783 times)
bullethead63
« on: January 31, 2013, 08:41:26 pm »
...they worked on the WAY to work...but not on the way home...bulbs all OK,indicator light on speedo INOP,as well...all connectors in headlight bird's nest seem OK...ugh...some stupid connection undone SOMEWHERE...where to start,fellow Bulleteers?Suggestions?
bullethead63
Re: '99 DeLuxe,10K miles...turn signals not working...WTF?
« Reply #1 on: January 31, 2013, 09:16:33 pm »
OK...for now,I shall retire with an ale,and Pete Snidal's excellent manual...it's dark,and even in NW Florida,it's a balmy 40 degrees...too cold to work outside...all hail Lord Lucas,Prince of Darkness...I'll check back tomorrow...
mrunderhill1975a
« Reply #2 on: January 31, 2013, 10:17:37 pm »
Check the flasher unit under the seat.  Has it become dislodged?
« Reply #3 on: January 31, 2013, 11:41:27 pm »
as a rule, if one side quits it could be a bulb or ground,
if all quit it's gotta be a power source....
Mr. Hill is right, check the flasher and source TO IT.
                -mike
bullethead63
« Reply #4 on: February 01, 2013, 07:03:28 am »
I had considered that...I may have a spare flasher unit from my '99 parts bike...I'll dig it out this weekend,and swap them out...may be it's just a loose connection to the flasher,anyway...thanks,Mike!
darmst6829
« Reply #5 on: February 05, 2013, 11:32:09 pm »
Check your battery for full charge?
Dave
